[gdal-dev] Can't build gdal in x64
Mihaela Gaspar mihaela.gaspar at urbanrobotics.net
Mon May 13 11:14:58 PDT 2013
More info on issue: I seem to build from VS but not from command line.
I put (to build in Win32)
!IFNDEF PLATFORM
PLATFORM=WIN32!ENDIF
Modified to
!IFNDEF PLATFORM
PLATFORM=x64!ENDIF
(to build in x64) - And it worked. But only if I build from inside Visual
Studio.
I would like to be able to use a bat file (and build alll
platform/configurations) The above - while it builds in VS, it will not
build from command line (with commands:
start /b /wait nmake -f makefile.vc clean
start /b /wait nmake.exe /f makefile.vc PLATFORM=x64
start /b /wait nmake.exe /f makefile.vc devinstall PLATFORM=x64
The exact same thing builds in Win32...
On Mon, May 13, 2013 at 8:53 AM, Mihaela Gaspar <
mihaela.gaspar at urbanrobotics.net> wrote:
> I am trying to build GDAL (1.9.2) in x64.
> In the instructions, I see:
> # Uncomment the following if you are building for 64-bit windows# (x64). You'll need to have PATH, INCLUDE and LIB set up for 64-bit# compiles.!IF "$(PLATFORM)" == "x64"
> WIN64=YES!ENDIF
>  And then, lower,
> # Under win64, symbols for function names lack the underscore prefix# present on win32. Also the STDCALL calling convention is not used.!IFDEF WIN64!UNDEF STDCALL!ELSE
> SYM_PREFIX=_!ENDIF
>  Can't find a PATH, INCLUDE and LIB specific for x64, or anything else
> that I should do...
> I can build in Win32.
> In x64, I get linker errors:
> LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
> LINK : error LNK2001: unresolved external symbol _OSRValidate...
> gdal19.dll : fatal error LNK1120: 74 unresolved externals
>  Please help.
> Thank you.
*Mihaela Gaspar*
*Urban Robotics Inc.**
*Software Engineer
33 NW First Avenue, Suite 200 | Portland, OR 97209
c: 971-269-9649
http://www.urbanrobotics.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130513/d0de6200/attachment.html>
