[gdal-dev] Can't build gdal in x64
Mihaela Gaspar mihaela.gaspar at urbanrobotics.net
Mon May 13 11:51:39 PDT 2013
Thank you.
I have all the dependent libraries built in Win32 and x64, and have set the
correct paths to platform/configuration
Also, pls see my question update - before building, I run a clean.
On Mon, May 13, 2013 at 11:43 AM, Jeff McKenna <
jmckenna at gatewaygeomatics.com> wrote:
> On 2013-05-13 12:53 PM, Mihaela Gaspar wrote:
> > In x64,I get linker errors:
> > |LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
> > LINK : error LNK2001: unresolved external symbol _OSRValidate
> > gdal19.dll : fatal error LNK1120: 74 unresolved externals|
> Note that before I switch from building GDAL from x32 to x64, I have to
> rebuild *all* of the dependent libraries in x64 (this is the hardest
> part of the whole process).
> Also note to make sure that you run "nmake /f makefile.vc clean" before
> each build.
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
*Mihaela Gaspar*
*Urban Robotics Inc.**
*Software Engineer
33 NW First Avenue, Suite 200 | Portland, OR 97209
c: 971-269-9649
http://www.urbanrobotics.net
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130513/7e527c76/attachment.html>
