[gdal-dev] gdalwarp does not apply source nodata value to destination
Etienne Tourigny etourigny.dev at gmail.com
Wed May 15 07:12:05 PDT 2013
I have just noticed that destination nodata value is not set when
-dstnodata option is not used in gdalwarp.
This can be problematic when warping a dataset with no data values, as the
result can be different from expected, if -dstnodata is not set.
gdalwarp does use source nodata pixels if -srcnodata is not used.
I consider this as a bug (or at the very least a limitation), because one
cannot warp a dataset in an automatic fashion and get expected output (with
same nodata value as input).
Would it be OK to copy them over if -dstnodata is not used, or would there
be problems with doing this? Or perhaps a new argument -copynodata could be
added if there is fear of disruption.
cheers
Etienne
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20130515/7a057012/attachment.html>
