[gdal-dev] Motion: Approve GDAL/OGR 1.10.1RC1 for release
Jack Howarth howarth at bromo.med.uc.edu
Fri Nov 8 08:02:46 PST 2013
On Fri, Nov 08, 2013 at 10:31:08AM -0500, Jack Howarth wrote:
> On Thu, Nov 07, 2013 at 04:34:07PM -0500, Jack Howarth wrote:
> > The failures on x86_64-apple-darwin13 for the png.py test suite from auto
> > test for gdal 0.10.1 are the same failures described here...
> > https://github.com/licq-im/licq/pull/32
> > <https://github.com/licq-im/licq/pull/32>
> > The failures are completely suppressed by regenerating
> > autotest/gdrivers/data/test.png with
> > "optipng -nb -nc -np test.png"...
> Just to clarify, I used optipng 0.6.3 for this. The newer optipng 0.7.4
> release seems more problematic as none of the obvious combination of options
> can fix the test.png file without changing the checksums and causing additional
> failures. So you will want to use the optipng 0.6.x release series to fix
> the bad png files in gdal.
Also, my tests here using optipng 0.7.4 to detect damaged png files indicate
that only data/gdalicon.png in gdal-0.10.1 needs to be fixed.
optipng -nb -nc -np -fix data/gdalicon.png
** Processing: data/gdalicon.png
Warning:
32x32 pixels, 4x8 bits/pixel, RGB+alpha
Recoverable errors found in input. Fixing...
Input IDAT size = 1964 bytes
Input file size = 2021 bytes
Trying:
  zc = 9  zm = 8  zs = 0  f = 0		IDAT size = 240
Selecting parameters:
Output IDAT size = 240 bytes (1724 bytes decrease)
Output file size = 313 bytes (1708 bytes = 84.51% decrease)
** Status report
1 file(s) have been processed.
1 error(s) have been encountered.
1 erroneous file(s) have been fixed.
> > % ./png.py
> >   TEST: png_1 ... success
> >   TEST: png_2 ... success
> >   TEST: png_3 ... success
> >   TEST: png_4 ... success
> >   TEST: png_5 ... success
> >   TEST: png_6 ... success
> >   TEST: png_7 ... success
> >   TEST: png_8 ... success
> >   TEST: png_9 ... success
> >   TEST: png_10 ... success
> >   TEST: png_11 ... success
> > Test Script: png
> > Succeeded: 11
> > Failed:    0 (0 blew exceptions)
> > Skipped:   0
> > Expected fail:0
> > Duration:  0.08s
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
