[gdal-dev] (no subject)
Federico Jurio federicojurio at suremptec.com.ar
Fri Nov 8 13:41:07 PST 2013
Hi all, I have a csv file named test.csv with the asociated test.vrt
*test.vrt*
<OGRVRTDataSource>
    <OGRVRTLayer name="test">
<SrcDataSource>C:\\Users\\FedericoJurio\\Desktop\\test.csv</SrcDataSource>
        <GeometryType>wkbPoint</GeometryType>
        <LayerSRS>WGS84</LayerSRS>
        <GeometryField encoding="PointFromColumns" x="Longitude"
y="Latitude"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
*test.csv*
Latitude,Longitude,Name
48.1,0.25,"First point"
49.2,1.1,"Second point"
47.5,0.75,"Third point"
In my code i can add the vrt file to the datasource successfully but when i
try to check the TestCapability(OLCRandomRead) from the correct layer
returns FALSE and i don't no why. Gdal can read the file from the console
with ogrinfo and everithing seems to be fine
*ogrinfo test.vrt*
INFO: Open of `test.vrt'
      using driver `VRT' successful.
1: test (Point)
Does anyone have any idea of why TestCapability returns false?
Thanks in advance,
Regards
Federico Jurio
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131108/c8e5ea0f/attachment-0001.html>
