[gdal-dev] ogr2ogr libcurl error
Even Rouault even.rouault at mines-paris.org
Thu Nov 21 13:34:00 PST 2013
Le jeudi 21 novembre 2013 15:14:05, David Reed a écrit :
> Hi, I am trying to get ogr2ogr working, but am getting the following error:
> dyld: Library not loaded: libcurl.4.dylib
>   Referenced from: /usr/local/bin/ogr2ogr
>   Reason: Incompatible library version: ogr2ogr requires version 8.0.0 or
> later, but libcurl.4.dylib provides version 7.0.0
> As I can tell, the latest curl is version 7
> (link)<http://curl.haxx.se/download.html>,
> why is this asking for version 8? I also tried to upgrade curl with brew
> but couldn't symlink into /usr/local, because would cause conflicts with
> the OS.
> Anyone have any ideas?
If you didn't define the --with-curl option when running GDAL ./configure, then
GDAL will link with the curl library indicated by "curl-config --libs"
You likley have several libcurl on your system and the one that got used when
linking GDAL is not the one available at runtime.
The 8.0.0 or 7.0.0 don't necessarily reflect the "human readable" version of
the curl library. It might be some other numbering scheme related to how the
API/ABI of the library evolves, or something linked to packaging.
> -Dave
Geospatial professional services
http://even.rouault.free.fr/services.html
