[gdal-dev] R: Re: GDAL 1.10.1 requirements
lauramail at iol.it lauramail at iol.it
Mon Oct 14 06:32:47 PDT 2013
Hi Even,
I had this error with a particular HDF5, it is strange because with the
previous version everything works (but I did not try with HDF5 1.8.9 and GDAL
1.9) .
Do you know that error message?
First of all I would like to understand if it is a library version problem or
not. I mean, I do not think the latest version is able to read less file than
the previous one but maybe there is something to set or different. Do you try
this new one?
Thanks
Laura
>----Messaggio originale----
>Da: even.rouault at mines-paris.org
>Data: 14/10/2013 13.36
>A: "laura0"<lauramail at iol.it>
>Cc: <gdal-dev at lists.osgeo.org>
>Ogg: Re: [gdal-dev] GDAL 1.10.1 requirements
>Selon laura0 <lauramail at iol.it>:
>> Hi all,
>> I would like to know which versions of netcdf, hdf4, hdf5 libraries are
>> supported by the new release of GDAL.
>> I tried for instance 4.1.1 netcdf library but, after ./configure, I see
>> "netcdf supported NO" .  So I think that version is too old. With the
latest
>> versions (netcdf 4.3.0, hdf5 1.8.11 , hdf4 4.2.9 ) everything looks going
>> fine but processing an hdf5 dataset I got the following error:
>> HDF5-DIAG: Error detected in HDF5 (1.8.11) thread 0:
>>   #000: H5A.c line 557 in H5Aopen(): unable to load attribute info from
>> object header for attribute: 'PRODUCT_NAME'
>>     major: Attribute
>> I was able to open the same dataset instead with gdal 1.9 and library
>> versions: hdf5 1.8.9 , hdf4 4.2.8 , netcdf 4.2.1.1
>> Is it a problem of versions or something else?
>Laura,
>I would have expected any netCDF version >= 3.6 or something like that to be
OK.
>But perhaps there are with particuler netCDF versions...
>On my dev system I have HDF5 1.8.4 I believe and things seem to work fine.
Are
>you encountering this error with all HDF5 datasets or just one particular one
>Did you try with HDF5 1.8.9 that worked with your GDAL 1.9 ?
>Even
