[gdal-dev] Colors and KML output
Tim Keitt tkeitt at utexas.edu
Tue Oct 29 19:36:29 PDT 2013
OK. Now I have my PEN styles loaded in the table. The KML driver is still
writing only red. Anyone how to get KML to use the OGR_STYLE column?
THK
On Tue, Oct 29, 2013 at 8:57 PM, Tim Keitt <tkeitt at utexas.edu> wrote:
> Thanks. I had seen that, but did not realize it was saying to write these
> string into a column in the database.
> THK
> On Tue, Oct 29, 2013 at 5:10 PM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi
> > wrote:
>> Tim Keitt <tkeitt <at> utexas.edu> writes:
>> > I'd like to set the color of line segments individually according to a
>> field in KML output. Is that possible? Seem it only outputs red. I can
>> change that globally, but not easily for many line segments.
>> > Looking at the driver code, there is some code there to handle colors. I
>> have no idea how to attach a color table to an ogr layer. Any hints on how
>> this works?
>> Have a try by adding an OGR_STYLE column and fill the colours for the
>> features as described in
>> http://www.gdal.org/ogr/ogr_feature_style.html
>> I have never tried that myself but perhaps it works.
>> -Jukka Rahkonen-
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.keittlab.org/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20131029/c19d546c/attachment.html>
