[gdal-dev] Colors and KML output
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Oct 29 22:54:58 PDT 2013
Tim Keitt <tkeitt <at> utexas.edu> writes:
> OK. Now I have my PEN styles loaded in the table. The KML driver is still
writing only red. Anyone how to get KML to use the OGR_STYLE column?
Have another try. I digitized some lines and set OGR_STYLE to something like
PEN(c:#0000FF,w:8px). Saved into shapefile and checked with ogrinfo
ogrinfo kml.shp kml
OGRFeature(kml):2
  OGR_STYLE (String) = PEN(c:#0000FF,w:8px)
  Style = PEN(c:#0000FF,w:8px)
OGR_STYLE attribute has been converted into feature style. Data are OK to
play with.
Then convert into kml with both "KML" and "LIBKML" drivers and check with
ogrinfo
KML driver
Style = PEN(c:#0000FFFF,w:8.000000px)
LIBKML driver
 Style = PEN(c:#0000FFFF,w:2.822228px)
Conclusion: Both drivers take the pen color. LIBKML is changing the line
width for some reason at least in this test. My features were reprojected
from EPSG:3067 into EPSG:4326 in my little test but I did not make further
tests to see if this is the reason. Anyway, I can change colors with GDAL
1.10 so I believe you will do the same soon.
I checked also with GE and colours do show.
-Jukka-
