[gdal-dev] severe memory leak when opening corrupt modis hdf (python bindings)
Vincent Schut schut at sarvision.nl
Thu Oct 31 04:29:58 PDT 2013
when opening a corrupt hdf4 modis product (I've put an example here:
http://sarvision.nl/~schut/gdal_corrupt_hdf/MYD09GQ.A2010007.h11v09.005.2010010052202.hdf)
with python, there is a severe memory leak (multiple GB!)
it is a dataset that gives "ERROR 4:
`/data/modis/MOLA/MYD09GQ.005/2010.01.07/MYD09GQ.A2010007.h11v09.005.2010010052202.hdf'
not recognised as a supported file format." when running gdalinfo on it.
When opening it with python (gdal.Open('...'), the result is None, but
there is a significant grow in memory usage that is only freed after
exiting python.
Can someone confirm? Just repeatedly running ds =
gdal.Open('MYD09GQ.A2010007.h11v09.005.2010010052202.hdf') should do it.
Well, maybe not repeatedly. Running it once already gets my memory usage
more than 2GB higher...
This is on gentoo linux, gdal from svn (updated yesterday), python
2.7.5, hdf 4.2.9, and also tested on Arch Linux.
Best regards,
Vincent.
