[gdal-dev] severe memory leak when opening corrupt modis hdf (python bindings)
Vincent Schut schut at sarvision.nl
Thu Oct 31 05:08:12 PDT 2013
On 10/31/2013 12:29 PM, Vincent Schut wrote:
> Hi,
> when opening a corrupt hdf4 modis product (I've put an example here:
> http://sarvision.nl/~schut/gdal_corrupt_hdf/MYD09GQ.A2010007.h11v09.005.2010010052202.hdf)
> with python, there is a severe memory leak (multiple GB!)
> it is a dataset that gives "ERROR 4:
> `/data/modis/MOLA/MYD09GQ.005/2010.01.07/MYD09GQ.A2010007.h11v09.005.2010010052202.hdf'
> not recognised as a supported file format." when running gdalinfo on
> it. When opening it with python (gdal.Open('...'), the result is None,
> but there is a significant grow in memory usage that is only freed
> after exiting python.
> Can someone confirm? Just repeatedly running ds =
> gdal.Open('MYD09GQ.A2010007.h11v09.005.2010010052202.hdf') should do
> it. Well, maybe not repeatedly. Running it once already gets my memory
> usage more than 2GB higher...
> This is on gentoo linux, gdal from svn (updated yesterday), python
> 2.7.5, hdf 4.2.9, and also tested on Arch Linux.
Update: it seems to be a hdf library problem, when I run hdfls on the
file, it also grows my memory with several GB. I also tried other
versions of libhdf (4.2.6, 4.2.8) but no difference...
> Best regards,
> Vincent.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
