[gdal-dev] GTiff stack to NetCDF
David Shean dshean at gmail.com
Tue Sep 3 09:59:50 PDT 2013
Done:
http://gis.stackexchange.com/questions/70458/convert-timeseries-stack-of-gtiff-raster-to-single-netcdf
Thanks for the responses.
D
On Sep 3, 2013, at 7:55 AM, "Signell, Richard" <rsignell at usgs.gov> wrote:
> David,
> If you post your question on the GIS stackexchange group
> I will provide an example code that should be helpful.
> -Rich
> On Tue, Sep 3, 2013 at 10:15 AM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> what you want is probably outside the scope of gdal. It would require some
>> clever metadata management so that gdal_translate puts them in a single
>> file...
>> I would advise you convert them all to netcdf using gdal_translate and then
>> use python-netcdf4 (not the one from numpy/scipy) to stack them in the
>> temporal dimension.
>> On Mon, Sep 2, 2013 at 7:09 PM, David Shean <dshean at gmail.com> wrote:
>>> Hi list,
>>> I'm trying to package a timeseries of GTiff rasters with identical
>>> projection/extent/resolution as a single NetCDF file for distribution.  I've
>>> spent the past hour consulting the online doc and playing with
>>> gdal_translate, gdalbuildvrt and gdalwarp without any success.
>>> Is there an easy way to do this using existing gdal command line
>>> utilities?  I figured I'd ask before resorting to a custom solution using
>>> the NetCDF Python API.
>>> Thanks.
>>> -David
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Dr. Richard P. Signell   (508) 457-2229
> USGS, 384 Woods Hole Rd.
> Woods Hole, MA 02543-1598
