[gdal-dev] A strange thing with a png geospatial file and gdalwarp. Is it a bug?
peifer peifer at gmx.eu
Wed Sep 4 04:55:11 PDT 2013
aborruso wrote
> Dear all,
> I have a geospatial png file - http://ge.tt/7tmMR7r/v/0?c -and gdalinfo
> give me this projection info:
> PROJCS["Popular Visualisation CRS / Mercator",
>     GEOGCS["Popular Visualisation CRS",
>         DATUM["Popular_Visualisation_Datum",
>             SPHEROID["Popular Visualisation Sphere",6378137,0,
>                 AUTHORITY["EPSG","7059"]],
>             TOWGS84[0,0,0,0,0,0,0],
>             AUTHORITY["EPSG","6055"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.01745329251994328,
>             AUTHORITY["EPSG","9122"]],
>         AUTHORITY["EPSG","4055"]],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     PROJECTION["Mercator_1SP"],
>     PARAMETER["central_meridian",0],
>     PARAMETER["scale_factor",1],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     AUTHORITY["EPSG","3785"],
>     AXIS["X",EAST],
>     AXIS["Y",NORTH]]
> It's EPSG:3785.
> If I run this command:
> gdalwarp -s_srs EPSG:3785 -t_srs EPSG:4326 -of GTiff "input.png"
> "output.tif"
> The output file has this extent:
> Upper Left  (  -0.6064394,  44.7016078) (  0d36'23.18"W, 44d42' 5.79"N)
> Lower Left  (  -0.6064394,  44.6980730) (  0d36'23.18"W, 44d41'53.06"N)
> Upper Right (  -0.5975973,  44.7016078) (  0d35'51.35"W, 44d42' 5.79"N)
> Lower Right (  -0.5975973,  44.6980730) (  0d35'51.35"W, 44d41'53.06"N)
> Center      (  -0.6020184,  44.6998404) (  0d36' 7.27"W, 44d41'59.43"N)
> If I run this command, without -s_srs parameter:
> gdalwarp  -t_srs EPSG:4326 -of GTiff "Avenue de Mont-de-Marsan.png"
> "male.tif"
> This output has an extent that is different from the previous (look at
> latitude):
> Upper Left  (  -0.6064394,  44.8937072) (  0d36'23.18"W, 44d53'37.35"N)
> Lower Left  (  -0.6064394,  44.8901724) (  0d36'23.18"W, 44d53'24.62"N)
> Upper Right (  -0.5975973,  44.8937072) (  0d35'51.35"W, 44d53'37.35"N)
> Lower Right (  -0.5975973,  44.8901724) (  0d35'51.35"W, 44d53'24.62"N)
> Center      (  -0.6020183,  44.8919398) (  0d36' 7.27"W, 44d53'30.98"N)
> Is it normal?
At least it isn't a bug. Without -s_srs, the CRS info from the png file is
used which specifies TOWGS84[0,0,0,0,0,0,0]. When specifying the EPSG code
via -s_srs, the parameter +nadgrids=@null is used (in both cases EPSG:3857
and EPSG:3785).
In the former case, a "change of ellipsoid" is performed during coordinate
transformation (from the sphere to WGS84), in the latter case, this isn't
done. The difference is a latitude-only offset of around 20 km. What you
usually want is the latter transformation, i.e.  no change of ellipsoid.
Hermann
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-strange-thing-with-a-png-geospatial-file-and-gdalwarp-Is-it-a-bug-tp5075948p5075998.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
