[gdal-dev] Update on RFC 41 implementation
Even Rouault even.rouault at mines-paris.org
Wed Sep 11 13:07:13 PDT 2013
Just to notify you that most of RFC 41 (multiple geometry field support in OGR)
has now been commited. The last remaining part will be the upgrade of the ILI
driver done by Pirmin.
As a bonus to the RFC, support for multiple geometry fields has also been added
to the SQLite SQL dialect (but not yet in SQLite table layer themselves)
I've also started "converting" a few OGR drivers (Shape, KML, LIBKML, GPX,
GML, VRT, GeoJSON, FileGDB, EDIGEO, OSM and GeoRSS) that are not in the scope
of RFC 41, so that the SRS of their unique geometry field definition is properly
set.
To know if a driver has been upgraded, it is a matter of running test_ogrsf on
a sample dataset and checking for the following warning :
WARNING: poLayer->GetSpatialRef() and poFDefn->GetGeomFieldDefn(0)-
>GetSpatialRef() differ.
If folks are willing to help upgrading other drivers, you're welcome !
http://trac.osgeo.org/gdal/changeset/26448 should show you how to do that in
simple situations.
This is mostly a matter of adding the following snippet :
if( poFeatureDefn->GetGeomFieldCount() != 0 )
    poFeatureDefn->GetGeomFieldDefn(0)->SetSpatialRef(poSRS);
and we can also remove the implementation of GetSpatialRef() that is then not
necessary ( the base implementation of OGRLayer::GetSpatialRef() will return
poFeatureDefn->GetGeomFieldDefn(0)->GetSpatialRef() )
For more complex situations (but I don't think there are a lot of such OGR
drivers), i.e. where there was lazy resolution of the SRS in
OGRLayer::GetSpatialRef(), the upgrade of the shapefile driver in
http://trac.osgeo.org/gdal/changeset/26442 can be used as an exemple.
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
