[gdal-dev] Gdalinfo does not print into file on Windows
Even Rouault even.rouault at mines-paris.org
Tue Sep 17 08:02:37 PDT 2013
Hi Jukka,
This reminds me a lot the following ticket :
http://trac.osgeo.org/gdal/ticket/5128
Could you confirm that the analysis done (i.e. the cause of the problem would be
the ECW plugin) also applies to you ? I'm not sure if you must completely
uninstall (or rename) the gdal_ECW.dll, or if specifying GDAL_SKIP=ECW as
environmenet variable is sufficient
Even
> Hi,
> I noticed that gdalinfo and gdallocationinfo tools do not print into file
> with command
> gdalinfo test.tif >report.txt
> The file report.txt is created but it remains empty. With ogrinfo printing
> into file goes well. I also had a try with some old FWTools and with that I
> could redirect also gdalinfo report into file.
> I was testing on Windows 7 and last nights 64-bit GDAL from trunk
http://gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver.zip
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
