[gdal-dev] Gdalinfo does not print into file on Windows
    Andre Joost
    andre+joost at nurfuerspam.de
    Tue Sep 17 11:31:59 PDT 2013
Am 17.09.2013 17:02, schrieb Even Rouault:
> Hi Jukka,
> This reminds me a lot the following ticket :
> http://trac.osgeo.org/gdal/ticket/5128
> Could you confirm that the analysis done (i.e. the cause of the problem would be
> the ECW plugin) also applies to you ? I'm not sure if you must completely
> uninstall (or rename) the gdal_ECW.dll, or if specifying GDAL_SKIP=ECW as
> environmenet variable is sufficient
Confirmed here. Removing or renaming the gdal_ECW_JP2ECW.dll in \bin
solves the problem. The file investigated was a .tif, so the ecw driver
was not used at all. Tested on gisinternals sdk version 1-10-0 from
07.09.2013.
HTH,
André Joost
