[gdal-dev] Build failed
Yves Jacolin yjacolin at free.fr
Sun Apr 6 13:28:43 PDT 2014
Hello,
I have a failure with gdal (still using gdal git repository):
/usr/bin/ld: /usr/local/src/gdal/gdal/frmts/o/.libs/aaigriddataset.o:
relocation R_X86_64_32S against `_ZTV14AAIGRasterBand' can not be used when
making a shared object; recompile with -fPIC
/usr/local/src/gdal/gdal/frmts/o/.libs/aaigriddataset.o: error adding symbols:
Bad value
collect2: error: ld returned 1 exit status
make[1]: *** [libgdal.la] Erreur 1
make[1]: quittant le répertoire « /usr/local/src/gdal/gdal »
make: *** [check-lib] Erreur 2
any idea?
Y.
Yves Jacolin
