[gdal-dev] Planning for 1.11.1 release ?
Even Rouault even.rouault at spatialys.com
Tue Aug 19 10:20:44 PDT 2014
Selon Flippmoke <flippmoke at gmail.com>:
> I wouldn't mind learning some of it, but would rather not being in charge of
> it.
Hi Blake,
The process is documented at http://svn.osgeo.org/gdal/trunk/gdal/HOWTO-RELEASE
To issue the release itself, most steps that require commit rights and access to
the OSGeo server. But there are other opportunities of helping, such as triaging
tickets, proposing patches or testing release candidate.
Even
> Thanks,
> Blake Thompson
> > On Aug 19, 2014, at 8:53 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Hi,
> > The 1.11 branch has accumulated 57 fixes [1] since the 1.11.0 release
> (perhaps a
> > bit more if some of them went to the 1.10 branch as well), so it might be
> good
> > to think producing a maintenance release with them.
> > What do you think of end of September to produce an RC (let's say September
> > 24th) ?
> > If there are outstanding regressions that should be fixed for 1.11.1, raise
> > tickets and cook up your patches !
> > There are 7 tickets currently opened against 1.11.1 milestone ([2]). GDAL
> > committers, please have a look at them and update milestone if needed.
> > Anyone volunteering to do the release process ? If nobody else wants, I
> will.
> > Best regards,
> > Even
> > [1]
http://trac.osgeo.org/gdal/query?status=closed&group=resolution&order=priority&milestone=1.11.1&resolution=fixed
> > [2]
http://trac.osgeo.org/gdal/query?status=assigned&status=new&status=reopened&group=resolution&order=priority&col=id&col=summary&col=owner&col=type&col=priority&col=component&col=version&milestone=1.11.1
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
