[gdal-dev] What is the maximum '-wm' I can use with 64bit gdalwarp?
Even Rouault even.rouault at spatialys.com
Wed Dec 24 01:50:23 PST 2014
Simen,
Up to 9999 for 9999 MB. And if you want more, you have to specified the value
in bytes instead of megabytes.
But putting more warp memory will not necessarily need to more performance,
especially if you mosaic many small images into a big one.
See
https://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp#WillincreasingRAMincreasethespeedofgdalwarp
Even
http://www.spatialys.com
