[gdal-dev] How to fix gdalwarp warning?
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Fri Feb  7 06:35:13 PST 2014
How does one do "Converting the dataset  prior to 24/32 bit is advised."?
Warning: Input file
/maps/images.tmp/844219fb7ca86093d82b14376b56b875/modis-chlo
ra-201402071850.tif has a color table, which will likely lead to bad
results whe
n using a resampling method other than nearest neighbour. Converting the
dataset
Thanks,
   -Steve
