[gdal-dev] Is there documetation about filters and some python utilities?
Frank Broniewski brfr at metrico.lu
Tue Feb 18 23:49:11 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Me too :-)
I've written a script which uses GDAL, mdenoise and ImageMagick to
create hillshade maps from SRTM which are more appealing than the
standard hillshade computation images. Python is used as a glue
between the commands and to provide a user interface on the command
line. You can have a look here [1] for inspiration ...
HTH
Frank
[1] https://bitbucket.org/metrico/pretty_hillshade/overview
Am 2014-02-18 23:11, schrieb Simon Shak:
> I perform similar tasks. While there are probably some internal
> methods inside python, I make calls to ImageMagick to perform the
> image manipulation. I first write a baseline tiff with the tfw
> with gdal_translate then preform convert commands to do the image
> processing then gdal_translate again to turn the baseline tiff and
> tfw back into a geotiff. On Feb 16, 2014 5:36 AM, "Jukka Rahkonen"
> <jukka.rahkonen at mmmtike.fi> wrote:
>> Hi,
>> I was thinking that a possibility to run images through filters
>> with GDAL could be nice sometimes. Especially for visual work
>> with aerial and satellite images filters like "sharpen" of
>> "unsharp mask" http://en.wikipedia.org/wiki/Unsharp_masking are
>> often very useful. But then I found that kernel filters can
>> already be used inside VRT files. Are there usage examples with
>> before-after comparison images somewhere in our documentation?
>> I also found that there are some python scripts included in
>> \gdal\bin\gdal\python\scripts at least in the gisinternals GDAL
>> builds but some scripts are not listed in
>> http://gdal.org/gdal_utilities.html.  Is there some other place
>> where to find documentation about these scripts, for example
>> gdal_calc.py ? Some other than the sources, I mean.
>> -Jukka Rahkonen-
>> _______________________________________________ gdal-dev mailing
>> list gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTBGHaAAoJEHopqW0d1cQVf/oIAKCAtpztALxkIpPQ7JK1vsoJ
HgNnxXzhgOI7cU3fd/xhEN3kWymDoCIFQEHAdScO7QpPGxBsM3h9wwJfJyrNfuWw
xSDDzUXGq9wNIh45Uz/74VOEePNb1F36RDDkkzKQRdJTdJwH/TF0qpEJt0Cilt4I
WjrHm+m4tcJZlIMA5BHeTTDEOLhMjr1IDHBFg19Dd0h2mfzsdKdwE1fdWegGv8pP
pT5qpFczjMhR4+LZ21yXR/wuBZC6KqnP2sL6NoyUgJFHiK1TGxwNzGi4aixfVqn2
0VltXy2tD+uEK1Z432EIkG9i3UBb4kj4VEwe3d801e0j5mVd/HVyE3oduPkJ60A=
=f7Qt
-----END PGP SIGNATURE-----
