[gdal-dev] Standard Dev. Environment?
Alan Boudreault aboudreault at mapgears.com
Fri Jan 10 10:41:27 PST 2014
The github: https://github.com/aboudreault/mapserver_dev-cookbook
Note that I started to upgrade the environment to be compatible with the
latest vagrant. I will also update the README file in the repo since the
procedure will be easier (since a few things I was using have been
directly integrated as vagrant plugin).
I plan to finish this during the next week.
Alan
On 14-01-10 01:36 PM, Daniel Morissette wrote:
> On 14-01-10 1:23 PM, Jay L. wrote:
>> Success.  Ivan, I used your ./configure flags - stock was also not
>> working on this VM.
>> I wonder if the dev. community is large enough to warrant storing a
>> lightweight Vagrant box image somewhere.
> Talking of Vagrant, FYI about a year ago Alan Boudreault wrote a set
> of Vagrant and Chef recipes to automate the setup of a MapServer dev
> environment (which includes GDAL as a dependency). The recipes are a
> bit old already, but it may be a good starting point for automating
> the setup of a GDAL dev environment.
> If you're interested, see:
> http://www.alanb.ca/blog/2013/03/09/setup-a-mapserver-development-environment-with-vagrant-and-chef/
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140110/0f447e7c/attachment.html>
