[gdal-dev] Standard Dev. Environment?
Homme Zwaagstra hrz at geodata.soton.ac.uk
Mon Jan 13 01:36:01 PST 2014
Hello,
On 10/01/14 18:23, Jay L. wrote:
> Success.  Ivan, I used your  ./configure flags - stock was also not working on this VM.
 > I wonder if the dev. community is large enough to warrant storing a
lightweight Vagrant box image somewhere.
Thinking along these lines, Docker has been getting a lot of traction lately
(http://www.docker.io) as a way to manage linux containers: I can see a
standard GDAL/OGR container with a broad selection of drivers being
useful in a
similar way to a Vagrant box image.
Container images can be hosted without cost to the community on the Docker
Index (https://index.docker.io).
See also <http://blog.docker.io/2013/11/introducing-trusted-builds/> as
a way
of automatically rebuilding a container image on the Docker Index every
time a
github commit is made.
Thanks,
Homme
> Thanks Frank, Evan and Ivan.
 > On Fri, Jan 10, 2014 at 9:54 AM, Ivan Lucena
<lucena_ivan at hotmail.com> wrote:
 >     I always build with:
 >       --with-libz=internal \
 >       --with-png=internal \
 >       --with-libtiff=internal \
 >       --with-geotiff=internal \
 >       --with-jpeg=internal \
 >       --with-gif=internal \
 >      If that helps...
 >     > Date: Fri, 10 Jan 2014 17:33:52 +0100
 >     > From: even.rouault at mines-paris.org
 >     > To: jlaura at asu.edu
 >     > CC: gdal-dev at lists.osgeo.org
 >     > Subject: Re: [gdal-dev] Standard Dev. Environment?
 >     > Jay,
 >     > hum it is well possible that the build with --without-jpeg
doesn't work and that
 >     > some drivers will try to use it. I haven't tried it for ages.
GDAL has an
 >     > internal version of libjpeg, so when you've no external
libjpeg, that one will
 >     > be picked up. I imagine that very few people test --without-jpeg.
 >     > Frank suggested you to just use plain "./configure". I'd
recommend strongly that
 >     > you just to try it. This must work well and autodetect which
libs are available
 >     > or not. The BuildingOnUnixWithMinimizedDrivers page you quote
represents a
 >     > non-standard configuration of GDAL, so you may hit rough corners.
 >     > To answer your question concerning the value for --with-jpeg,
it is the
 >     > installation prefix of libjpeg. Typically /usr for system jpeg
(but that one
 >     > would be picked up implicitely) or /usr/local (if you've
installed your own
 >     > libjpeg).
 >     > > Evan,
 >     > > Thanks for the info. One more question for you - make clean
worked, but I
 >     > > have hit another issue:
 >     > > After running `./configure --without-jpeg ...`, `make clean`,
`sudo make
 >     > > install`:
 >     > > /home/vagrant/gdal-1.10.1/libgdal.so: undefined reference to
 >     > > `jpeg_write_scanlines'
 >     > > `jpeg_CreateCompress'
 >     > > `jpeg_read_scanlines'
 >     > > So lib-jpeg is seen. This doesn't make sense since I have
--without-jpeg
 >     > > specified in the config. I looked in the config and must have
missed it -
 >     > > does a flag to specify the full PATH to libjpeg exist?
 >     > > Thanks,
 >     > > Jay
 >     > > On Fri, Jan 10, 2014 at 7:24 AM, Even Rouault
 >     > > <even.rouault at mines-paris.org>wrote:
 >     > > > Selon "Jay L." <jlaura at asu.edu>:
 >     > > > > Frank,
 >     > > > > Thanks for the heads up. I am using the --without-jasper
flag as part of
 >     > > > > the ./configure call. Here is the error that I am seeing
- that led to
 >     > > > me
 >     > > > > to believe that the issue is jasper related:
 >     > > > > make[1]: Entering directory `/home/vagrant/gdal-1.10.1/apps'
 >     > > > > g++ gdalinfo.o commonutils.o -L/home/vagrant/gdal-1.10.1
-lgdal
 >     > > > > -lpthread -lm -lrt -ldl -o gdalinfo
 >     > > > `dec_jpeg2000'
 >     > > > > collect2: ld returned 1 exit status
 >     > > > > make[1]: *** [gdalinfo] Error 1
 >     > > > > make[1]: Leaving directory `/home/vagrant/gdal-1.10.1/apps'
 >     > > > > make: *** [apps-target] Error 2
 >     > > > > I did install libjpeg-dev and libjasper-dev in hopes that
this would
 >     > > > > alleviate the issue.
 >     > > > > Perhaps I am pursuing the issue in the wrong direction?
 >     > > > When you run ./configure several times, make sure to run
"make clean"
 >     > > > between
 >     > > > the attempts. I'm not clear why you've had this error with the
 >     > > > "dec_jpeg2000"
 >     > > > symbol that is defined and used in the GRIB driver (it has
a definition
 >     > > > even if
 >     > > > you don't have Jasper). Anway the "make clean" will
probably solve it.
 >     > > > Generally, "./configure" without any particular argument
should work on
 >     > > > most
 >     > > > platforms.
 >     > > > > Thanks,
 >     > > > > Jay
 >     > > > > On Thu, Jan 9, 2014 at 9:33 PM, Frank Warmerdam
<warmerdam at pobox.com>
 >     > > > wrote:
 >     > > > > > Jay,
 >     > > > > > Are you needing Jasper? Normally a default build
("./configure")
 >     > > > should
 >     > > > > > work pretty well on a precise system. I'm guessing you
have enabled
 >     > > > jasper
 >     > > > > > because it is key to what you want to do? If not
--without-jasper
 >     > > > should
 >     > > > > > be straight forward.
 >     > > > > > Best regards,
 >     > > > > > Frank
 >     > > > > > On Thu, Jan 9, 2014 at 8:00 PM, Jay L. <jlaura at asu.edu>
wrote:
 >     > > > > >> List,
 >     > > > > >> I wonder if a standard dev. environment exists? I am
working to
 >     > > > extend a
 >     > > > > >> driver and am having trouble getting an environment
working that will
 >     > > > > >> compile. Current setup is a VagrantVM, Ubuntu 12.04
32-bit with
 >     > > > source
 >     > > > > >> downloaded from SVN. Attempting to build with minimized
 >     > > > > drivers<
http://trac.osgeo.org/gdal/wiki/BuildingOnUnixWithMinimizedDrivers>as
 >     > > > > per the build documentation and am having build errors due to
 >     > > > > >> dec_jpeg2000 (jasper I believe).
 >     > > > > >> Q: Are devs using a standard environment (or a
different flavor of
 >     > > > *nix?)?
 >     > > > > >> _______________________________________________
 >     > > > > >> gdal-dev mailing list
 >     > > > > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
 >     > > > > > I set the clouds in motion - turn up | Frank Warmerdam,
 >     > > > > > light and sound - activate the windows |
http://pobox.com/~warmerdam
 >     > > > > > and watch the world go round - Rush | Geospatial
Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140113/c2de645c/attachment-0001.html>
