[gdal-dev] gdal_grid: number of data points to use
Even Rouault even.rouault at mines-paris.org
Sat Jan 18 04:50:15 PST 2014
Le samedi 18 janvier 2014 12:48:23, Jan Hartmann a écrit :
> gdal_grid has the option to set a minimum and maximum number of data
> points to use for interpolation. How are these data points selected from
> the total number of points? Are they always the nearest points to the
> grid-point that is interpolated?
Jan,
if less than min_points match the selection of the algorithm, the nodata value
will be returned
and when iterating over source points (in the order they are present in the
source OGR layer), the algorithm will stop as soon as max_points is reached.
The selected points are consequently not necessarily the nearest points, but
they will be contained in the search ellipse (since max_points is only taken
into account if you define radius1 and radius2)
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
