[gdal-dev] Error with VagrantFile due to postgis-gdal dependency
Jorge Arevalo jorgearevalo at libregis.org
Tue Jul 8 15:13:18 PDT 2014
Hello,
I'm testing the VagrantFile included in GDAL trunk to create a development
environment for GDAL, based on Vagrant. I'm following the instructions [1],
but getting an error [2]
Looks like the problem is the dependency between PostGIS and GDAL. The
vagrant script tries to install PostGIS before GDAL, but PostGIS depends on
GDAL (I think it's just a PostGIS Raster issue, not sure about it).
If I comment the PostGIS part in the VagrantFile, it works. Tested with
trunk and 1.11.0 versions. Using Vagrant 1.5.4 on a Mac OS Mountain Lion
machine.
Is anyone else having the same problem?
Best regards,
Jorge Arevalo
Freelance developer
http://about.me/jorgeas80
[1] http://trac.osgeo.org/gdal/wiki/Vagrant
[2]
https://dl.dropboxusercontent.com/u/6599273/errors/gdal/vagrant_gdal_error.log
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140709/d2c33111/attachment.html>
