[gdal-dev] warp taking time
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jul 10 03:14:15 PDT 2014
garfy,
Please provide the gdalwarp command you used. Did you modify GDAL_CACHEMAX?
On Thu, Jul 10, 2014 at 3:26 PM, garfy <adiba.nizami at gmail.com> wrote:
> Dear All,
> I am trying to generate mosaic of 28 input images using *gdalwarp*.
> All are in same projection. It has taken 5 days to generate the final
> output.
> Please find the gdalinfo of input and output attached. The input files are
> passed to warp in the order in which the gdalinfo is present in the
> attachement.
> Any input on improving the time would be really helpful.
> Thanks
> input_files_gdalinfo.txt
> http://osgeo-org.1560.x6.nabble.com/file/n5150453/input_files_gdalinfo.txt
> final_output_gdalinfo.txt
> http://osgeo-org.1560.x6.nabble.com/file/n5150453/final_output_gdalinfo.txt
> http://osgeo-org.1560.x6.nabble.com/warp-taking-time-tp5150453.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140710/29d1ceba/attachment.html>
