[gdal-dev] warp taking time
Thornton, Michele M. thorntonmm at ornl.gov
Thu Jul 10 06:53:27 PDT 2014
Hello,
I’m interested in this thread.  One comment I can add about gdal_merge.py is that it does not properly handle nodata values from the full (padded) extent of the input files.  gdalwarp, which can be VERY slow, does handle the nodata values correctly.
Michele Thornton
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of bas smit
Sent: Thursday, July 10, 2014 7:52 AM
To: Chaitanya kumar CH
Cc: gdal dev
Subject: Re: [gdal-dev] warp taking time
I am wondering why you are using gdalwarp for mosaicing images having same projection instead of gdal_merge.py?
Bas Smit
On Thu, Jul 10, 2014 at 7:14 PM, Chaitanya kumar CH <chaitanya.ch at gmail.com<mailto:chaitanya.ch at gmail.com>> wrote:
garfy,
Please provide the gdalwarp command you used. Did you modify GDAL_CACHEMAX?
On Thu, Jul 10, 2014 at 3:26 PM, garfy <adiba.nizami at gmail.com<mailto:adiba.nizami at gmail.com>> wrote:
Dear All,
I am trying to generate mosaic of 28 input images using *gdalwarp*.
All are in same projection. It has taken 5 days to generate the final
output.
Please find the gdalinfo of input and output attached. The input files are
passed to warp in the order in which the gdalinfo is present in the
attachement.
Any input on improving the time would be really helpful.
Thanks
input_files_gdalinfo.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5150453/input_files_gdalinfo.txt>
final_output_gdalinfo.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5150453/final_output_gdalinfo.txt>
View this message in context: http://osgeo-org.1560.x6.nabble.com/warp-taking-time-tp5150453.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
+91-9494447584<tel:%2B91-9494447584>
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140710/487e6daa/attachment-0001.html>
