[gdal-dev] gdal installation, geopdf not recognized
Eli Adam eadam at co.lincoln.or.us
Mon Jul 14 15:05:05 PDT 2014
On Mon, Jul 14, 2014 at 12:35 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Eli,
>> > On Mon, 14. Jul 2014 at 10:40:08 -0700, Eli Adam wrote:
>> >> Searching through trac for OSGeo4W, I found this which seems like it might
>> >> be similar, http://trac.osgeo.org/osgeo4w/ticket/408
>> > I can't reproduce that.  WI_Madison_West_20130722_TM_geo.pdf works fine
>> > with both the 32 and the 64bit build in OSGeo4W (using gdal-1.11.0-2).
>> Before I try updating OSGeo4W and seeing if anything changes, is there
>> anything else to try to find the source of the error?  My install is
>> the result of an advanced install about three months ago and probably
>> updated about a month or two ago.
> Ok, that's explains it.  #408 tries to explain that 1.11.0-2 is from
> 9 days ago and introduces pdf read support - earlier didn't have it.
More carefully reading, I now see that the fix was 9 days ago.  I
updated and as expected OSGeo4W reads geopdf fine.
Thanks, Eli
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
