[gdal-dev] Which format is the best identify a spatial reference ?
Even Rouault even.rouault at mines-paris.org
Tue Jul 15 11:48:50 PDT 2014
Le mardi 15 juillet 2014 09:45:22, orel a écrit :
> Hi,
> Spatial references objects can be imported / exported using OGR API to
> multiple formats : proj4, WKT, XML...
> Can I use one of these as a format "which describes properly every spatial
> reference" ?
> For example, if I use WKT as "internal format" for my application, is there
> any chance that a projection described with a proj4 string (or an EPSG code
> or whatever...) cannot be properly converted to a WKT string ?
WKT is a reasonable choice.
It might be possible that some exotic proj4 projection methods are not mapped
as OGRSpatialReference (which directly maps to/from WKT) recognized methods,
but unless you've very specific needs, that should not hurt you.
The same applies with EPSG codes. Only a few methods used by EPSG SRS have no
equivalent in the OGRSpatialReference world.
> My goal is to use a single spatial reference format when storing/loading
> work sessions of my application.
> Thanks.
> http://osgeo-org.1560.x6.nabble.com/Which-format-is-the-best-identify-a-sp
> atial-reference-tp5151074.html Sent from the GDAL - Dev mailing list
> archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Geospatial professional services
http://even.rouault.free.fr/services.html
