[gdal-dev] Lambert 93 problem with GDAL 1.11.0
Even Rouault even.rouault at mines-paris.org
Thu Jul 17 11:55:17 PDT 2014
Le jeudi 17 juillet 2014 16:31:42, Frédéric Trastour a écrit :
> Hi,
> It seems that in your wkt standard_parallel_1 et standard_parallel_2 values
> are inverted. Take a look at :
> http://spatialreference.org/ref/epsg/2154/prettywkt/
In LCC_2SP, the roles of StdP1 and StdP2 can be switched indifferently, so the
WKT is OK.
Actually I've put the WKT in a lambert93.wkt file and tested with the false
easting, northing and observed that the result is the central meridian,
latitude of origin :
$ gdaltransform -s_srs lambert93.wkt -t_srs EPSG:4171
700000 6600000
3 46.4999999999999 0
So that looks OK.
Are you sure the data is correct and/or consistant with the projection ?
Even
Geospatial professional services
http://even.rouault.free.fr/services.html
