[gdal-dev] Lambert 93 problem with GDAL 1.11.0
Andre Joost andre+joost at nurfuerspam.de
Fri Jul 18 08:13:44 PDT 2014
Am 18.07.2014 08:36, schrieb orel:
> Thanks for spotted this, but it doesn't change anything.
> I've uploaded the file here :
> http://speedy.sh/vNEcQ/test-bati-pts2.zip
> <http://speedy.sh/vNEcQ/test-bati-pts2.zip>
> If I display it, using GlobalMapper for example (or my osgEarth based
> application), the data are in the right place.
> If I reproject it using "ogr2ogr -t_srs" to EPSG:4326 or EPSG:3857 (or any
> other I guess) the point are then moved by more than 100 km.
Not for me. Using gisinternals/sdk build of GDAL 1.11.0, and QGIS for
display, the points fit perfectly. Same if I reproject using QGIS.
Maybe your self-built GDAL is somehow broken.
Greetings,
André Joost
