[gdal-dev] GDAL 1.7.3 can't read tiff written by GDAL 1.11
Eli Adam eadam at co.lincoln.or.us
Mon Jul 21 15:02:32 PDT 2014
On Mon, Jul 21, 2014 at 1:46 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> Le lundi 21 juillet 2014 22:18:27, Eli Adam a écrit :
>>  Hi all,
>> I've got some recent tiff data that can't be read by GDAL 1.7.3
>> ("gdalinfo.exe has stopped working").  It appears to work fine with
>> GDAL 1.11.  The output from GDAL 1.11 can't be read by GDAL 1.7.3
>> either.  Hmm, oddly it seems to work with GDAL 1.6.
>> I have an older MapServer and GDAL that I'd like to use with new data
>> without updating MapServer and GDAL so my goal is find a way to use or
>> alter the data so it is usable by GDAL 1.7.3.  I also want to know if
>> the data is valid and complies with the the geotif specification.
> Looks reasonable at first sight
>> This is on Windows 7 and OSGeo4W although I also had some similar
>> issues on Ubuntu 10.04.  Below are GDAL 1.11 version, gdalinfo with
>> debug, listgeo, and finally gdal_translate output that can't be read
>> by GDAL 1.7.3 (attached).  There are messages about "GTIFF: converting
>> geokey to meters to fix bug in old libgeotiff"
> Yes, tricky issue with non-meter linear unit. See ticket
> https://trac.osgeo.org/gdal/ticket/3901 to get heavily confused.
I read that and am somewhat confused :) but have a basic understanding
of it as well now.  I tried gdal_translate -projwin 7367110 520505
7367120 520495 06S08W19.tif 06S08W19_gdal1_11_ouput3.tif --config
GTIFF_LINEAR_UNITS BROKEN to try and make a broken tiff to see if it
would work.  GDAL 1.7.3 can't read the output of that either.
> Related to that, I guess your listgeo is from libgeotiff 1.3 or older since it
> should display ProjFalseEastingGeoKey: 2500000.000000 m normally
Using the OSGeo4W installer libgeotiff appears to be 1.3.0-3 (is there
a command line option to determine libgeotiff or libtiff version?).
I just looked these up on EPSG and now my basic understanding of
ticket 3901 is faltering.
http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::6558&entity=urn:ogc:def:crs:EPSG::6559&reportDetail=long&style=urn:uuid:report-style:default-with-urn&style_name=OGP%20Default%20With%20Urn&title=Oregon_foot_meter
Is it incorrect to report ProjFalseOriginEastingGeoKey (Double,1):
8202099.73753281 with ProjLinearUnitsGeoKey (Short,1): Linear_Foot?
>> and "TIFFReadDirectory:
>> Warning, Unknown field with tag 2457 (0x999) encountered."
> Cannot find its definition in the TIFF tag catalog, but shouldn't cause issues.
> This will be ignored
>> Further
>> below the GDAL1.11 information, is GDAL 1.7.3 showing that it can't be
>> read and the error output.
>> Do 06S08W19_gdal1_11_ouput2.tif and 06S08W19.tif conform to the geotif
>> specification and contain valid data? Any suggestions on how to keep
>> using my older install without updating?
> I managed to read your attachef file with latest state of 1.7 branch (1.7.3
> with a few additional fixes) on Linux, and cannot see anything in the log
> between this and 1.7.3 that could explain the issue. However, as more or less
> expected, the georeferencing is not read correctly (since #3901 was fixed in
> 1.8) and the false easting value is multiplied by 1. / 0.3048.
Would different versions of libgeotiff explain it working (with
incorrect georeferencing?) for you and erroring out for me?
> You will never (or with much difficulty) manage to make it work with non-meter
> linear units in old GDAL releases. I'd encourage you warping it into a UTM
> projection for example.
Thanks for the suggestion.  I'll pursue this and it sounds like this
will work for me.
Best regards, Eli
> Best regards,
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html
