[gdal-dev] VRTDataset in Java
Ivan Lucena lucena_ivan at hotmail.com
Mon Jun 9 13:58:12 PDT 2014
Hi there,
What is the best option to create in memory VRT Dataset with the GDAL Java API?
I would like to do thing like gdal_translate does [0], band selection and window cropping for example.
It seems like the VRTDataset class is not wrapped in Java, so I would need to write the XML myself or use a regular GDAL Dataset clas, ex.:
Dataset ds = dal.getDriverByName("VRT").Create("/vsimem/xxx.vrt", 255, 255);
But there are some methods in VRTDataset that GDALDataset doesn't have, so I think I am going with the raw XML option.
Any better idea?
Best regards,
Ivan
ref. :
[0] http://trac.osgeo.org/gdal/browser/trunk/gdal/apps/gdal_translate.cpp#L1095
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140609/3768e906/attachment.html>
