[gdal-dev] VRTDataset in Java
Ivan Lucena lucena_ivan at hotmail.com
Tue Jun 10 06:04:20 PDT 2014
Do we have plans to add those entries to the GDAL API (C, Java, etc.)?
---------- \...\GDAL\TRUNK\FRMTS\VRT\GDAL_VRT.H
VRTDatasetH CPL_DLL CPL_STDCALL VRTCreate( int, int );
CPLXMLNode CPL_DLL * CPL_STDCALL VRTSerializeToXML( VRTDatasetH, const char * );
CPLErr CPL_STDCALL VRTAddSource( VRTSourcedRasterBandH, VRTSourceH );
CPLErr CPL_DLL CPL_STDCALL VRTAddSimpleSource( VRTSourcedRasterBandH,
CPLErr CPL_DLL CPL_STDCALL VRTAddComplexSource( VRTSourcedRasterBandH,
To: gdal-dev at lists.osgeo.org
Date: Mon, 9 Jun 2014 16:58:12 -0400
Subject: [gdal-dev] VRTDataset in Java
Hi there,
What is the best option to create in memory VRT Dataset with the GDAL Java API?
I would like to do thing like gdal_translate does [0], band selection and window cropping for example.
It seems like the VRTDataset class is not wrapped in Java, so I would need to write the XML myself or use a regular GDAL Dataset clas, ex.:
Dataset ds = dal.getDriverByName("VRT").Create("/vsimem/xxx.vrt", 255, 255);
But there are some methods in VRTDataset that GDALDataset doesn't have, so I think I am going with the raw XML option.
Any better idea?
Best regards,
Ivan
ref. :
[0] http://trac.osgeo.org/gdal/browser/trunk/gdal/apps/gdal_translate.cpp#L1095
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140610/835665c8/attachment-0001.html>
