[gdal-dev] OT: openev(2) alternative?
Joaquim Luis jluis at ualg.pt
Fri Jun 20 07:03:15 PDT 2014
On 20-06-2014 14:45, Vincent Schut wrote:
> On 06/20/2014 03:39 PM, Joaquim Luis wrote:
>> If you are on Windows and 32 bits is not a (severe) limitation, I
>> think Mirone (http://w3.ualg.pt/~jluis/mirone) satisfies those
>> requisites
> Ah, sorry, should have mentioned that: I'm on linux (64bit). 32 bit is
> a limitation anyway, I regularly need to view very large images... Btw
> building experimental stuff is no problem.
Ah.
It can be made to work on Linux as well but than one needs Matlab (no 32
bits restriction in that case)
> Vincent.
>> Joaquim
>>> Hi list,
>>> this is a bit off topic, but I guess I'll have the biggest chance
>>> for an answer on this ml...
>>> Untill now, I always succeeded in (re)building openev2, but after
>>> some recent system upgrades, it fails... I've used openev2 (and
>>> openev before that) long as my preferred raster viewer. It is
>>> blazingly fast, and has almost all functionality I want from a
>>> viewer. Especially an easy mechanism to set which bands are r,g and
>>> b, and to adjust the stretch, are important to me. And displaying
>>> multiple rasters on top of each other, being able to easily switch
>>> them on and off.
>>> Now I'm afraid I need to look for an alternative. There once were
>>> rumours of an openev3, but afaik that has never really materialized?
>>> I've tried several others (tuiview, monteverdi(2), qgis, thuban,
>>> otbiceviewer, ...) but none of them has the combination of being
>>> fast and convenient.
>>> I just need something that is good in displaying (browsing, zooming)
>>> multi-band raster files. Anybody knows a viable alternative?
>>> Thanks!
>>> Vincent.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
