[gdal-dev] gdal 1.11 unable to read netcdf files
00darki alex.jong0019 at gmail.com
Fri Jun 27 08:11:32 PDT 2014
..I found a solution, simply copy .dll files in a subdirectory called
/gdalplugins in the /apps directory .. it seems to works fine (with an error
on gdal_GEOR.dll)
*d:\GDAL\gdal-1-11\bin\gdal\apps>gdalinfo.exe D:/GDAL/MapServer/mnt00000.nc
ERROR 1: Can't load requested DLL:
d:\GDAL\gdal-1-11\bin\gdal\apps\gdalplugins\gdal_GEOR.dll
193: %1 nÆest pas une application Win32 valide.
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
Driver: netCDF/Network Common Data Format
Files: D:/GDAL/MapServer/mnt00000.nc
Size is 4321, 2161
Coordinate System is `'
Metadata:
  NC_GLOBAL#latitude_max=90
  NC_GLOBAL#latitude_min=-90
  NC_GLOBAL#longitude_max=180
  NC_GLOBAL#longitude_min=-180
  profondeurs#desc=GRILLE
  profondeurs#name=Profondeur
  profondeurs#units=metre
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 2161.0)
Upper Right ( 4321.0,    0.0)
Lower Right ( 4321.0, 2161.0)
Center      ( 2160.5, 1080.5)
Band 1 Block=4321x1 Type=Float32, ColorInterp=Undefined
  NoData Value=9.969209968386869e+036
  Metadata:
    desc=GRILLE
    name=Profondeur
    NETCDF_VARNAME=profondeurs
    units=metre*
Thank you for your answer :)
Problem solved
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-gdal-1-11-unable-to-read-netcdf-files-tp5148406p5148434.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
