[gdal-dev] Problem with results on two different versions of gdal_wrap
Stephen Woodbridge woodbri at swoodbridge.com
Sun Mar 9 15:17:13 PDT 2014
On 3/8/2014 5:22 AM, Even Rouault wrote:
>> This is the problem step:
>> gdalwarp -rcs -ts 8800 6600 -s_srs EPSG:32662 -t_srs EPSG:4326 temp.tif
>> target.tif
>> gdalinfo -mm -stats target.tif
>> is showing that the range of values in the image are dramatically
>> different on the two servers!
>> summary old:
>> Band 1 Block=8800x1 Type=Int16, ColorInterp=Gray
>>       Computed Min/Max=-3877.000,32767.000
>>     Minimum=-3877.000, Maximum=32767.000, Mean=25235.731, StdDev=10612.642
>> summary new:
>>     Min=-9314.000 Max=32561.000   Computed Min/Max=-9314.000,32561.000
>>     Minimum=-9314.000, Maximum=32561.000, Mean=19166.800, StdDev=7786.806
>> Ok, so you can see that the values are radically different. My question
>> is how do I get values like the old system? These values represent
>> temperatures and I need to get the same values.
>> My one thought on this is that if is another side effrct of proj4
>> behaving differently as I had to adjust the position above to get it to
>> align. So maybe the gdalwarp is messing up the pixel values when it
>> reprojects it also. But I'm totally lost on how make this work correctly.
>> Any thoughts on how to fix this?
> Stephen,
> I think we already had a discussion some time ago about differences between
> spherical or ellipsoidal projections, or am I confusing with someone else ?
Yes this is probably reloaded to the previous discussion sine this is
the same process that we discussed before. Before I was dealing with the
projection being misaligned and I fixed that by changing the bbox
defined for the hdf file so it was aligned.
But now I am realizing that the pixel values are also messed up. So
maybe changing the bbox was not the right thing to do.
> Well, it is not clear from your experiment if the difference is due to
> reprojection or to the resampling method.
Yeah, I am totally lost on this. My experiment was to compare the
process steps on each system to see where things we different in the
hope of understand what is happening.
> There's a difference between both GDAL versions, but is the new result worse
> than the previous one (from visual inspection) ?
The images do look similar.
> Cubic spline resampling seems to produce overshoot artifacts in both
> situations (since -3877.000 or -9314.000 in output < 377 in input). That's
> probably due to the maths behind.
Right, but turning that off and using the default does not resolve the
issue.
> Maybe just try with the default nearest resampling to see if it is due to the
> resampling kernel or the reprojection.
Tried that, no joy.
> I'm also wondering if your data doesn't have a nodata value that you should
> explicitely set. As I can only guesswould be a good candidate given
> that the data type is Int16. But the " _FillValue=[65535]" in the metadata
> makes me wonder if the datatype shouldn't be UInt16 rather than Int16 in your
> initial conversion from netcdf to geotiff, and the nodata would rather be 65535
I tried setting setting nodata and tried UInt16. I notice in the hdf
metadata that there was a valid_range=[0-32767] which might have been
why the Int16 as being used.
Anyway, as I mentioned in the prior email, I'm waiting on some docs for
the hdf files and I will try to reconstruct the process from that.
-Steve
> Even
