[gdal-dev] Gdal GeoTIFFs in MapInfo
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Mar 12 05:44:00 PDT 2014
Hi Even,
> Well, I don't know MapInfo limits with raster files. Perhaps is it just big
> raster dimensions that cause problem, or tiling, or .. ?
I guess it's size. I've tried with no compression, no tiles, and both no
compression or tiling, all fail. So I guess a MapInfo thing then.
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140312/cd08e400/attachment.html>
