[gdal-dev] GML / NAS code redundancy
Martin Landa landa.martin at gmail.com
Tue Mar 18 09:55:37 PDT 2014
Hi Even,
2014-03-18 17:50 GMT+01:00 Even Rouault <even.rouault at mines-paris.org>:
> I haven't looket at the file but from the above, the logic of the application
> schema registry would need to be extended since it currently only supports one
> feature type per file. You would need to ingest the full file to recognize which
> feature types are in it.
at this time I am not sure if to follow gml_registry.xml approach or
to write a new specialized driver for this format. I already started
to write a new driver, but it's similar situation to NAS driver. There
will similar duplication of the code compared to NAS...
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
