[gdal-dev] Compile gdal/ogr with mingw
David Tran david.tran at hsr.ch
Thu Mar 27 05:51:01 PDT 2014
Hi to everyone
Did somebody compile gdal/ogr with mingw?
I tried to compile gdal (static/shared) with MinGW without success of
calling the function OGRRegisterAll() in QT 5.2.1 (C++). Starting the
binary results in:
 > The program has unexpectedly finished.
I used those tutorials:
http://gvsigce.sourceforge.net/wiki/index.php/Compiling_the_C/C%2B%2B_support_libraries
http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
http://www.gdal.org/ogr/ogr_apitut.html
and this shell script with updated version numbers:
http://sourceforge.net/p/gvsigce/code/HEAD/tree/trunk/support/build_scripts/build_gdal_binaries_mingw.sh
My System:
Windows 8.1,
Expat 2.1.0
GDAL 1.10.1
Geos 3.4.2
Openssl 1.0.1f
PostgreSQL 9.3.4
Proj.4 4.8.0 (Datumgrid 1.6RC1)
Sqlite 3080401
zlib 1.2.8
Two versions of MinGW 32bit were used at the same time for gdal to compile:
http://sourceforge.net/projects/mingw/files/
and
http://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win32/Personal%20Builds/rubenvb/gcc-4.8-release/i686-w64-mingw32-gcc-4.8.0-win32_rubenvb.7z/download
PATH: C:\MinGW\bin;C:\mingw32\bin
cheers
David
