[gdal-dev] OGR-trunk plugin fails to load
Ivan Lucena lucena_ivan at hotmail.com
Wed May 28 05:32:19 PDT 2014
Hi Even,
I svn updated trunk and I build the OGR/OCI driver as a plugin and it fail to load.
$ gdalinfo --version
ERROR 1: dlsym(0x7fac63d051f0, _GDALRegisterMe): symbol not found
ERROR 1: dlsym(0x7fac63d051f0, _GDALRegister_CI): symbol not found
GDAL 2.0.0dev, released 2014/04/16
That is OSX 10.9. I haven't try on other systems yet.
I also build the GDAL/GeoRaster driver as a plugin and that seems to be fine.
It seems like a general problem, not only for that driver. So if you can try to build another OGR driver as a plugin you might find that same issue.
Regards,
Ivan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140528/93fade29/attachment.html>
