[gdal-dev] OGR-trunk plugin fails to load
Even Rouault even.rouault at mines-paris.org
Wed May 28 06:26:46 PDT 2014
Le mercredi 28 mai 2014 14:32:19, Ivan Lucena a écrit :
> Hi Even,
> I svn updated trunk and I build the OGR/OCI driver as a plugin and it fail
> to load.
> $ gdalinfo --version
> ERROR 1: dlsym(0x7fac63d051f0, _GDALRegisterMe): symbol not found
> ERROR 1: dlsym(0x7fac63d051f0, _GDALRegister_CI): symbol not found
> GDAL 2.0.0dev, released 2014/04/16
> That is OSX 10.9. I haven't try on other systems yet.
> I also build the GDAL/GeoRaster driver as a plugin and that seems to be
> fine.
> It seems like a general problem, not only for that driver. So if you can
> try to build another OGR driver as a plugin you might find that same
> issue.
Indeed. Should be fixed now.
> Regards,
> Ivan
Geospatial professional services
http://even.rouault.free.fr/services.html
