[gdal-dev] GDAl no more compiling on Ubunut 12.0.4
Rémi Cura remi.cura at gmail.com
Mon Oct 13 01:14:36 PDT 2014
Hey,
Thanks for the help !
I started from a fresh git clone,
it compiled fine using the regular autotools.
Again from fresh git clone, cmake works fine.
It seems the bug is produced by
_ mixing autotools and cmake
_using a virtual box shared folder filesystem
So anybody using virtualbox shared file system must be careful (performance
hit is about 2 time also).
Cheers,
Rémi-C
2014-10-10 18:32 GMT+02:00 Eli Adam <eadam at co.lincoln.or.us>:
> > It compiled GDAL on Ubuntu 12.0.4 LTS about 6 months ago.
> > Today I updated the git sources,
> > a new error at the very beginning of compilation stops everything
> > "Configure" seems to have changed a lot.
> > Any suggestions?
> I can compile svn trunk on 12.04 as of today.  I started with a make
> clean and then this is my configure:
> ./configure --with-poppler --with-spatialite=yes --with-java=yes
> --with-mdb=yes --with-python --with-curl --with-expat --with-libkml
> make clean might help.  There are a lot of different libraries which
> can be internal or external and many combinations to test so not sure
> how similar my setup is to yours.
> Best regards, Eli
> > Cheers,
> > Rémi-C
> > //////////error//////////
> > In file included from cpl_conv.h:35:0,
> >                  from cpl_conv.cpp:33:
> > cpl_port.h:89:2: error: #error "Unexpected value for SIZEOF_INT"
> > cpl_port.h:93:2: error: #error "Unexpected value for
> SIZEOF_UNSIGNED_LONG"
> > cpl_port.h:97:2: error: #error "Unexpected value for SIZEOF_VOIDP"
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141013/3ca8b9e2/attachment.html>
