[gdal-dev] Transform pixel coordinates
    Andre Joost
    andre+joost at nurfuerspam.de
    Sat Oct 25 01:05:41 PDT 2014
Am 25.10.2014 um 09:29 schrieb Artur Bercik:
> sorry, yes the pixel size are in degrees,0.047 deg.(5 km approx. at
> equator), in GCS and WGS84.
Ok, then it is easy. Using the values from your other post:
upperLeftX, upperLeftY = 150.1234, 50.1234 (They are in GCS with WGS84
datum)
pixelWidth, pixelHeight = 0.047, 0.047
totalColumns, TotalRows = 270, 406
and assuming the coordinates are East and North positive. To
georeference the image, set the extent in gdal_translate with -a_srs
EPSG:4326 and -a_ullr ulx uly lrx lry
ulx and uly are known, the others are
lrx = ulx + 270 * 0.047
lry = uly - 406 * 0.047
This does not work if your image is not North-orientated.
HTH,
André Joost
