[gdal-dev] Migrate to GDAL v2 or not?
Paul Meems bontepaarden at gmail.com
Mon Sep 29 12:50:52 PDT 2014
Thanks Even for the quick reply.
We like bleeding edge technology ;) So we'll be using GDAL v2.
If we stumble on something I'll post it on this list.
Thanks,
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
*The English presentations of the MapWindow GIS Conference 2014 are online.
<http://www.slideshare.net/mapwindow>*
2014-09-29 21:00 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> Paul,
> It is difficult to answer on your behalf. If you need new features of GDAL
> 2,
> then it is pretty obvious. Otherwise it depends on if you are confortable
> with
> using a "non vetted" development version (but whose quality you can assess
> by
> running the autotest suite), because you want to do progressive adoption
> (it
> is not excluded that there will be extra interface changes before GDAL 2),
> or
> want to stick with something with a more official label. But we definitely
> need
> early adopters to make it a memorable release.
> Best regards,
> Even
> > We, at the MapWinGIS project, have been using GDAL for years and since
> last
> > year we're using Tamas his pre-build binaries.
> > We're now in the middle of upgrading from Visual Studio 2008 to Visual
> > Studio 2013 and wonder if this is also a good moment to upgrade from GDAl
> > v1.11 to GDAL v2.
> > We already recompiled using GDAL v2 and it seems we have only a few
> issues
> > which seems to be easily fixed.
> > We won't release a new version of MapWinGIS within a few months, probably
> > around X-Mas.
> > What is recommended?
> > Thanks,
> > Paul
> > *Paul Meems *
> > www.mapwindow.org
> > www.mapwindow.nl
> online.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140929/94483dae/attachment.html>
