[gdal-dev] support for Czech Exchange Format for Land Consolidation
Martin Landa landa.martin at gmail.com
Thu Apr 2 08:07:58 PDT 2015
Hi Even,
2014-09-23 16:56 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
first of all, thanks for your notes.
I would like to start working on implementation within next weeks.
> Although I've always felt intimated by its syntax, I imagine you could write a
> XSLT document that would transform the above XML in GML. Easier solution is to
Right, there is even XSD available for this format [1].
> do it off-line (i.e. outside GDAL), otherwise if you want something transparent
Sure, but GDAL is preferable solution.
> to the user, we could have a generic XML driver that would try several XSLT
> documents and then feed the transformed document to the GML driver. I don't
Anybody here is interested to implement such driver or at least to
collaborate on such project?
> If you go with a from-the-scratch driver, I would not recommand to go from the
> GML one which has become very complicated. GeoRSS or GPX are probably better
> starting points.
Right, this also an option, generic driver would be better.
Martin
[1] http://spucr.cz/frontend/webroot/uploads/files/2015/02/vfp_2596.0596.xsd
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
