[gdal-dev] RFC 57: 64-bit bucket counts for histograms
Even Rouault even.rouault at spatialys.com
Wed Apr 8 01:06:38 PDT 2015
>  A similar problem exists with GDALRasterBand::GetRasterSampleOverview():
> it takes a 31-bit integer value for its 'nDesiredSamples' parameter.  I've
> run into some 100,000×100,000-pixel images for which the first two levels
> of overviews would contain more than 2-billion samples.
Hi Craig,
Good point. I've updated the RFC and proposed implementation accordingly.
Even
http://www.spatialys.com
