[gdal-dev] OGR style feature
Even Rouault even.rouault at spatialys.com
Fri Apr 17 01:33:54 PDT 2015
Le vendredi 17 avril 2015 10:24:17, Luca Delucchi a écrit :
> Hi devs,
> I'm working on a QGIS plugin to export GeospatialPDF.
> I have problems to use the "Symbol Name" according to OGR style feature
> page [0] The "Symbol Name or ID" of SYMBOL Tool are working really well
> but the "Symbol Name or ID" of PEN and BRUSH are not working for me.
> these are the style applied to my features (they seems correct)
> polygon BRUSH(fc:#4fbb87ff,id:"ogr-brush-7");PEN(c:#000000ff,w:0.26mm,j:b)
> point SYMBOL(id:"ogr-sym-7",c:#ffff00ff,o:#000000ff,w:3mm)
> lines PEN(c:#919ce5ff,w:2mm,j:r,cap:p,id:"ogr-pen-5")
Luca,
it is documented in http://gdal.org/frmt_pdf.html that id is only supported on
SYMBOL for PDF export, but not on PEN and BRUSH.
For dashed line, you can use the p/pattern attribute instead.
For non-solid polygon fill, this would have to be implemented.
Best regards,
Even
http://www.spatialys.com
