[gdal-dev] building interface to org2org
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 20 04:49:59 PDT 2015
Błażej Doruch <blazej.doruch <at> gmail.com> writes:
> org2gui looks nice, but there is no support for EPSG that I need.Blaze
I rather believe that there is some bug that cuts loads of supported
projections from the drop-down menu. Try adding your projections directly
into the Options box in ogr2ogr syntax, for example
-s_srs epsg:4326 -t_srs epsg:2175
With those options ogr2gui wrote a shapefile for me with a .prj file
PROJCS["Pulkovo_1942_58_Poland_zone_V",GEOGCS["GCS_Pulkovo
1942(58)",DATUM["D_Pulkovo_1942_Adj_1958",SPHEROID["Krasovsky_1940",
6378245,298.3]],PRIMEM["Greenwich",0],UNIT["Degree",
0.017453292519943295]],PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",
18.95833333333333],PARAMETER["scale_factor",0.999983],
PARAMETER["false_easting",237000],PARAMETER["false_northing",
-4700000],UNIT["Meter",1]].
-Jukka Rahkonen-
