[gdal-dev] building interface to org2org
Błażej Doruch blazej.doruch at gmail.com
Tue Apr 21 01:05:36 PDT 2015
Thanks for suggestion, now it's working
Blaze
2015-04-20 13:49 GMT+02:00 Jukka Rahkonen <
jukka.rahkonen at maanmittauslaitos.fi>:
> Błażej Doruch <blazej.doruch <at> gmail.com> writes:
> > org2gui looks nice, but there is no support for EPSG that I need.Blaze
> I rather believe that there is some bug that cuts loads of supported
> projections from the drop-down menu. Try adding your projections directly
> into the Options box in ogr2ogr syntax, for example
> -s_srs epsg:4326 -t_srs epsg:2175
> With those options ogr2gui wrote a shapefile for me with a .prj file
> PROJCS["Pulkovo_1942_58_Poland_zone_V",GEOGCS["GCS_Pulkovo
> 1942(58)",DATUM["D_Pulkovo_1942_Adj_1958",SPHEROID["Krasovsky_1940",
> 6378245,298.3]],PRIMEM["Greenwich",0],UNIT["Degree",
> 0.017453292519943295]],PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",
> 18.95833333333333],PARAMETER["scale_factor",0.999983],
> PARAMETER["false_easting",237000],PARAMETER["false_northing",
> -4700000],UNIT["Meter",1]].
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Błażej Doruch
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150421/399d272a/attachment.html>
